Home » Audio » Speaker » Tweeters? More or Better.....
Re: Tweeters? More or Better..... [message #22345 is a reply to message #22344] Tue, 19 October 2004 09:34 Go to previous messageGo to previous message
Bill is currently offline  Bill
Thanks for the reply. I have never built a line array but I have built several DIY speakers.
I just bought 20 of the VIFA TC18WG-15-08 7" INFINITY WOOFER at PE for $9.00. It was a deal I couldn't pass up. I plan to use 9 a-side and keep 2 as spares...just in case.
My thoughts on tweeters are:
1. go with the pt-2 planar. I have not heard them and would like to know other's opinions. I have some reservations about using a "budget" planar as I was not happy with the sound of the BG NEO-3 and the Freq. Respon. seems to roll off above 5K (depends on the graph you go by). I am not sure if I will be able to buy enough to equal the height of the line exactly but may come close.
2. buy as many North creek D25-06S ($36 per pair)as my budget will allow. I have heard them and like them, for the price. But in light of your reply this does not seem like a good way to go as I will not be able to afford enough to equal the height of the mid/bass array
3. Use the Stryke audio SA-TW1 . they have it for $7.00 and it doesn't look bad, from what little info there is on it. Any one heard it?
What are your thoughts on combing effects if I try to go the dome route and try to stretch them out to fit the height of the array?
Bill
Previous Topic: Home Theater line array's
Next Topic: Kleinhorn
Current Time: Tue Nov 24 15:06:17 CST 2026
