Home » Audio » Speaker » New array - some questions
Re: New array - some questions [message #22331 is a reply to message #22330] Fri, 15 October 2004 09:58 Go to previous messageGo to previous message
I'm building the same thing your making the only difference is I'm using 24 of tweeters aside.
>>What cabinet volume would be appropriate, or how can I calculate it?
Follow the link and put in the parameters of the driver in the database maintenance and run the program.
>>I am looking at 3/3/6/8 arrangement for the 4" and 5/5/6/6/8 for the 3/8". Is this proper tapering?
Yes and you will need to do it, I have to do this on my tweeter array for sure, I discovered that when I was testing the array.
>>Would a ported cabinet work better?
Somewhat depends on where your x-over point to the sub is, but your still not going to get much below 100Hz. And with the somewhat hi Qts of the drivers it'll require a larger cabinet.
HTH
Bill W.
Previous Topic: Singular horns
Next Topic: Stephens Trusonic 80FR
Current Time: Mon Nov 02 10:01:30 CST 2026
