Home » Audio » Speaker » More thoughts on slot vs. hole for mounting array drivers
Re: More thoughts on slot vs. hole for mounting array drivers [message #22295 is a reply to message #22294] Mon, 13 September 2004 20:46 Go to previous messageGo to previous message
taylor is currently offline  taylor
You are right about the mounting. Im going to mount them on the front of the two halve baffles and once the frames are butted together, you wouldnt be able to tell that holes werent used. I was thinking of sealing the gap between the baffles and the butted drivers with silicone or maybe a thick adhesive material like the sound deadening stuff autosound guys use. If used dipole, the sealing isnt as critical but Im going seal box so it definately needs close attention.
taylor
Previous Topic: AG trio or JBL K2 9800?
Next Topic: Single driver cornerhorn
Current Time: Fri Nov 06 01:43:05 CST 2026
