Home » Audio » Speaker » Line array question using Bandor 50mm driver?
Re: Line array question using Bandor 50mm driver? [message #22280 is a reply to message #22278] Sun, 05 September 2004 07:59 Go to previous messageGo to previous message
The combing effect here would only extend a few inches out from the baffle at best, so that's not a particular concern. What would likely be problematic is off-axis response. The axial charts look OK out to 12kHz or so but with a 50mm radiating plane it's a very safe bet that the -6dB response at 30 degrees off-axis won't extend beyond 10kHz at best. Good HF dispersion requires no more than a 25mm radiating plane with point source drivers, and smaller than that is even better.
Previous Topic: Truncated horns
Next Topic: BR + TL + FH
Current Time: Sat Oct 31 16:34:02 CDT 2026
