Home » Audio » Speaker » Line array with single ribbon tweeter
Re: Line array with single ribbon tweeter [message #22249 is a reply to message #22248] Tue, 31 August 2004 15:15 Go to previous messageGo to previous message
The shift from the narrow vertical dispersion of the near field to the wider vertical dispersion of the far field with a four inch (.1 meter) high radiating plane will take place approximately .02 meters from that plane at 1400 Hz. You don't need to use multiple mid drivers to match that; a single 6 1/2" midbass would be quite adequate, and you only need be concerned if you're actually listening at a distance of .02 meters or less. As far as the narrowing vertical dispersion at progressively higher frequencies is concerned, that's a good thing; don't worry about it.
Previous Topic: Push-Pull horns
Next Topic: cheap units in europe
Current Time: Fri Oct 16 17:14:46 CDT 2026
