Home » Audio » Speaker » questions on array wiring and such....
Re: Answers on Array Wiring [message #22222 is a reply to message #22221] Mon, 16 August 2004 20:10 Go to previous messageGo to previous message
HOMEMADE is currently offline  HOMEMADE
Hi Jim , and thank-you for your response. I thought my idea of wiring all tweeters in parallel might not be the way to go. I was hoping for a very simple(?) assembly for this project. I have looked over your white paper and I'm trying to absorb all the theory. I want my first attempt to be inexpensive(cheap). I purchased 100 2x3.5" drivers from Styke audio(.60ea.), and plan on starting with a design he has.PE has the tweeters (.32ea), which look to have a 1" pole on the back . 1" holes should not be to bad. I have subs that I can c/o @150hz , so I might take an easy route and use a folded OB. I have been playing with some short lines(36")and I do like what I here , using 5" coaxial car speakers. I do beleive if I find this set-up to have merit , I'll most likely try one of the proven designs available. I am quite happy about the array gain on the tweeters; to bad about the wiring. Paul
Previous Topic: Modify or remanufacture?
Next Topic: Bill Fitzmaurice, How's your Line Array hybrid coming along?
Current Time: Wed Nov 04 18:28:12 CST 2026
