Home » Audio » Speaker » Jim and Bill - PT2 array gain
Re: Jim and Bill - PT2 array gain [message #22216 is a reply to message #22215] Sun, 15 August 2004 21:11 Go to previous messageGo to previous message
Allan,
Thanks for the measurements. For a passive crossover you can use a contour circuit to equalize the upper octave a bit but at the expense of lower overall response (less sensitivity) for the Pt2 line. If you have tone controls or an equalizer, then you can sweeten the upper octave a bit to your taste.
Before you do anything though, I suggest that you listen and decide if you have adequate treble from the array. All too often you might find that a flat response all the way to 20 kHz will sound a little too bright in-room.
Jim
Previous Topic: Martinelli Horns
Next Topic: Any ESL/planar to work with Aleph 3?
Current Time: Wed Nov 04 04:33:44 CST 2026
