Home » Audio » Speaker » Driver Center to Center Spacing for Line Arrays
Re: Driver Center to Center Spacing for Line Arrays [message #22207 is a reply to message #22199] Sun, 08 August 2004 23:46 Go to previous messageGo to previous message
jdybnis is currently offline  jdybnis
Jim,
I've gone and read the JBL reference. I'm getting a bit lost in terminology. Am I using the the phrase correctly if when I say a speaker is directive I mean that the off-axis response is poor? The JBL paper seems to use it to mean the opposite. Also what do 'directivity factor' and DI mean? They are the labels on the vertical axis of graph 1B.
Graph 4B seems to show horizontal lobing. Is this a separate effect than the vertical comb filtering you describe in your whitepaper?
-Josh
Previous Topic: Diaphragm materials for compression drivers
Next Topic: Outdoor / Patio speaker rec.
Current Time: Tue Sep 22 01:48:53 CDT 2026
