Home » Audio » Speaker » compression horn tweeter
Re: It won't work. [message #22181 is a reply to message #22180] Thu, 29 July 2004 11:56 Go to previous messageGo to previous message
T lines do need to be properly designed and for the most part aren't used as subs as there are better/smaller ways. Full range T lines that will go to 20 Hz are viable- see Legacy.
A baffle board only works but you give up a lot of sensitivity and bass response with them. Some people like them a lot- try the planar forum at Audio Asylum.
Bi-amping requires an active crossover to operate.
Arrays can be built 3 way or 4 way if you wish, but most are 2 way.
I don't understand the last question, but I do use both EQ and a limiter on my HT system.
Previous Topic: new DIY speaker
Next Topic: Taking a wild guess here about cross-over design
Current Time: Tue Nov 03 20:43:39 CST 2026
