Home » Audio » Speaker » compression horn tweeter
Re: It won't work. [message #22176 is a reply to message #22175] Wed, 28 July 2004 14:11 Go to previous messageGo to previous message
mike erb is currently offline  mike erb
thanks ,is it the 80" length or the small width ?,i've been looking at car audio softdome tweeters can buy them wholesale for $1.50 a set
also ,what size mids do you think are the best ,can use 16 each 5.25" or 18 each 4.5" or 24 each 3.5" all cheap though parts express closeout sale ,also do i need to have a bass blocker and at what frequency like 80hz or higher like 120hz? and do that many drivers wired series/parallel change your crossover points ,sould i bi-amp or not also thought about an electronic crossover ,this would only work if i bi-amp'd ofcourse.this is going to be a 7.1 surround system the three fronts left ,right ,center will be the only line array speakers ,thought this infomation may help.thanks
Previous Topic: new DIY speaker
Next Topic: Taking a wild guess here about cross-over design
Current Time: Wed Nov 04 01:38:18 CST 2026
