Home » Audio » Speaker » LA HF horns
Much simpler than you may think. [message #22173 is a reply to message #22172] Tue, 27 July 2004 12:55 Go to previous message
What's critical is the distance between the radiating planes of the individual elements, which ideally is kept under a wavelength. This rules out 1" domes that have 2" wide mounting flanges but other options are available. A simple rule of thumb states that if the radiating plane of the array comprises are least 90% of the meaured vertical plane then you're OK. Where horns are concerned the radiating area is the horn mouth, exclusive of the mounting flange.
Previous Topic: Very nice cabinet work for Fostex 168
Next Topic: Corner Placement: In or Out?
Current Time: Sat Nov 28 18:44:41 CST 2026
