Home » Audio » Speaker » Hey Bill when does?
Re: It was made by fostex it's the fe 103 stamped on the back [message #22162 is a reply to message #22161] Fri, 16 July 2004 13:47 Go to previous message
I'm not sure if the Rat Shack model is the same driver as the Fostex catalog unit, and a lot depends on vintage. I remember the Rat Shack FE103 was an acoustic suspension midbass back in 1968, and I don't think it's that one. Anyway, the current Fostex has an Fs of 80Hz and Qts of .35, so if yours are close to those specs they would work in my TLAH pretty flat down to 100 Hz. At the other end the off-axis starts getting hinky above 6kHz, the same as the drivers I used, so it's close enough there also.
Previous Topic: Eminence LA6
Next Topic: Sprinkling posts...
Current Time: Sat Nov 28 18:07:57 CST 2026
