Home » Audio » Speaker » bessel arrays?
Re: bessel arrays? [message #22135 is a reply to message #22134] Tue, 06 July 2004 06:51 Go to previous message
I favor near field line arrays as I detail in my white paper on this subject. Depending on the number of drivers that you array, you can achieve 10 dB or more additional sensitivity. You will likely need a line of tweeters to handle the highs as the 40-1197 shouldn't be used much above about 4000 Hz because of comb lining.
The Bessel array thought is a non-starter in my opinion as it is far field effect and likely not compatible with usage in a normal listening room. Bessel arrays have little to offer.
Jim
Previous Topic: Improvements to Straight 8's
Next Topic: bessel arrays?
Current Time: Tue Oct 20 03:24:26 CDT 2026
