Home » Audio » Speaker » Qes affected by series parellel
Re: Qes affected by series parellel [message #22131 is a reply to message #22129] Sat, 26 June 2004 13:09 Go to previous message
lcholke is currently offline  lcholke
Hi Jim,
>Qes remains the same for the array as for a single driver.
So If the array is wired in any 8 ohm configuration the Qes stays unchanged.
I was hoping that Qes would explain the change.
I wired the 4 drivers in series. Then these 4 sets in parallel. ( 8 ohm )
>What you might experience is that you have increased the 'head room' for the array vs. single driver.
>Hence, the array will effectively have the amount of the array gain improvement in dynamic range.
I really like the 12db gain, and all the improvements that go with it.
The 4x array I started with ( OB, no xover ) sounded very good.
Wired as 2 sets in series, these then in parallel (8 ohm).
I have a pic posted here as PE .87 16x array , http://fullrangedriver.com/tiki-browse_gallery.php?galleryId=2.
Something is odd with the 16x array sound though.The impact of the sound is more like proac tablets (over dampened) than a fostex bk-16 back loaded horn (lively) . I first covered with blankets the top 4 and bottom 4 drivers to see if a cancellation was the problem. No real change. I was thinking that the curve of the baffle might have an odd comb effect.
So I checked the wiring on the 16x array about six times thinking I missed something.
I have now rewired to 8 total drivers/ side, 2x series combined to 4 sets parallel. (4 ohm total)
The impact came back. Just as a ref note, the amp is a pass labs alpeh 5.
I was hoping/thinking that the change had to do with the electrical dampening of the drivers.
Finding the cause of a problem is most of the battle.
Thanks for your help.
Linc
Previous Topic: Love these 2 inchers!
Next Topic: Single drivers, open baffles and baffle steps
Current Time: Thu Nov 05 19:22:26 CST 2026
