Home » Audio » Speaker » Array types
Re: Array types [message #22117 is a reply to message #22116] Tue, 08 June 2004 12:23 Go to previous messageGo to previous message
>>Is a line source always a vertical array?
Yes, they have a very very narrow vertical dispersion, while maintaining a wide horizontal dispersion.
>>Is a Bessel array always square?
Usually, or close to it, so you can do some neat things with them, like high SPL's or for beam steering applications and frequency shading and some other things. JBL has a tech paper on beam steering and freq. shading for bessel arrays and the principles behind it, see link below.
Phillips corporation holds the patent and licensing for Bessel arrays so if you're going to use them commercialy(sp) you may need a license.
HTH
Bill W.
Previous Topic: Brief review of EV LS-8's
Next Topic: fullrange cones and whizzers, some observations
Current Time: Tue Sep 01 22:24:38 CDT 2026
