Home » Audio » Speaker » Floor bounce
Re: Floor bounce [message #21812 is a reply to message #21811] Tue, 15 May 2007 10:25 Go to previous messageGo to previous message
As you suggest, there isn't much that you can do about floor bounce with a single driver speaker. You could put the driver at the floor, but then the sound stage will be on the floor and that is really annoying. The drivers on my speakers work out to be ~32" off of the floor. The sound stage is a little low, but livable. I find that the best sound stage is with the driver ~45" off of the floor. One thing you might try is to put a coffee table or large hassock between you and the speakers. That will block a large part of the floor bounce and the bounce off of the table will be at a higher frequency. Maybe a good thing, maybe not.
Bob
Previous Topic: Project Studio Monitors
Next Topic: Neo 8 / neo3 xo
Current Time: Fri Nov 06 00:38:26 CST 2026
