Home » Audio » Speaker » P AUDIO - 15" DRIVER AND BAFFLE DESIGN
| Re: I know my input is not wanted here... [message #21730 is a reply to message #21687] |
Thu, 26 October 2006 16:14   |
Retsel
Messages: 23 Registered: May 2009
Chancellor |
The Silver Iris drivers use a stamped frame driver. Using a pair of stamped frame drivers, Linkwitz measured some resonances in the midrange band caused by the stamped frame. It is better to use cast frame drivers OR mount the stamped frame drivers by the magnet. There is no free lunch when it comes to frequency response. If you try to reproduce the lower frequencies with a driver that you are asking to also reproduce the midrange frequencies with, you will muddy up the midrange (it is doppler distortion which is a function of physics). The problem is worse using a high Q driver because of its weaker magnet. Thus, it is much better to keep the lower frequencies (below 100 hz) out of the midrange driver and biamp to keep those frequencies out of the amp as well. Linkwitz tried many drivers and concluded that OB sound is best with drivers with a Q of 0.4 to 0.5. It is a function of damping (even though that Linkwitz used SS amps, not tube amps). I am sure that the Silver Iris drivers sound good, but if your goal is only good sound, then you're done (and you may not care about the midrange distortion, which is fine too). But if you are after great sound, then you really need to be looking elsewhere. Retsel
Re: P AUDIO - 15" DRIVER AND BAFFLE DESIGN
By: akhilesh on Tue, 22 August 2006 06:31
By: FredT on Tue, 22 August 2006 07:07
How about the T/S specs of the Silver Iris by Hawthorne?
By: akhilesh on Tue, 22 August 2006 10:21
Eminence Alpha 12 and 15
Re: Eminence Alpha 12 and 15
By: akhilesh on Tue, 22 August 2006 11:15
Well, see, it's this way....
Re: Well, see, it's this way....
By: DanTheMan on Fri, 01 September 2006 00:03
By: DanTheMan on Sun, 03 September 2006 03:49
By: DanTheMan on Mon, 04 September 2006 16:49
By: Martin on Thu, 31 August 2006 08:04
By: Martin on Thu, 31 August 2006 16:41
By: gfederys on Wed, 20 September 2006 13:49
By: gfederys on Thu, 21 September 2006 06:42
By: FredT on Wed, 23 August 2006 06:50
By: Retsel on Thu, 26 October 2006 16:14
Re: How about the T/S specs of the Silver Iris by Hawthorne?
By: FredT on Tue, 22 August 2006 13:44
By: FredT on Thu, 26 October 2006 18:41
By: Retsel on Mon, 28 August 2006 16:25
Current Time: Tue Nov 03 09:41:01 CST 2026
