Home » Audio » Speaker » P AUDIO - 15" DRIVER AND BAFFLE DESIGN
| Re: Well, see, it's this way.... [message #21705 is a reply to message #21697] |
Thu, 31 August 2006 08:04   |
Martin
Messages: 220 Registered: May 2009
Master |
Dave, I have not heard the Silver Iris but I have now changed the woofers in my Lowther OB system to the Eminence Alpha A15 which has a Qts of about 1.2, I updated my site to reflect this yesterday. I think these Eminence drivers are very close (if not the same) to the Silver Iris 15 inch driver. The bass is as you describe, deeper and warmer compared to the lower Qts Dayton drivers I was using before and could easily support a smaller baffle. With my big baffle the bass goes very low for an OB system. The one difference in the Silver Iris and my system is the location of the crossover point. I am rolling the Eminence drivers out at 200 Hz using a 12 dB/octave filter. Obviously the Silver Iris uses the woofer to a much higher frequency which may or may not be a concern. I will have to play with my active crossover to see how things work crossing over higher. Would you happen to know at what frequency the Silver Iris corsses to the coaxial horn tweeter? But based on my experience with the Eminence Alpha driver, I bet the Silver Iris sounds very good in a "smaller" OB at a great price point. Martin
Re: P AUDIO - 15" DRIVER AND BAFFLE DESIGN
By: akhilesh on Tue, 22 August 2006 06:31
By: FredT on Tue, 22 August 2006 07:07
How about the T/S specs of the Silver Iris by Hawthorne?
By: akhilesh on Tue, 22 August 2006 10:21
Eminence Alpha 12 and 15
Re: Eminence Alpha 12 and 15
By: akhilesh on Tue, 22 August 2006 11:15
I know my input is not wanted here...
Re: I know my input is not wanted here...
By: DanTheMan on Fri, 01 September 2006 00:03
By: DanTheMan on Sun, 03 September 2006 03:49
By: DanTheMan on Mon, 04 September 2006 16:49
By: Martin on Thu, 31 August 2006 08:04
By: Martin on Thu, 31 August 2006 16:41
By: gfederys on Wed, 20 September 2006 13:49
By: gfederys on Thu, 21 September 2006 06:42
By: FredT on Wed, 23 August 2006 06:50
By: Retsel on Thu, 26 October 2006 16:14
Re: How about the T/S specs of the Silver Iris by Hawthorne?
By: FredT on Tue, 22 August 2006 13:44
By: FredT on Thu, 26 October 2006 18:41
By: Retsel on Mon, 28 August 2006 16:25
Current Time: Tue Nov 03 09:41:47 CST 2026
