Home » Audio » Speaker » OPen baffle designs
Re: Good advice [message #21698 is a reply to message #21694] Wed, 30 August 2006 15:25 Go to previous messageGo to previous message
Retsel is currently offline  Retsel
I am still playing with my design, but I only have problems with one recording - Burmester's recording of Chinese drums. The Lowther is moving more than several millimeters and may be bottoming out. I tried a higher crossover which effectively eliminated the overextersion of the Lowther driver even with the Chinese drums recording and in my case the sound was not as good. But in my case I know the reason why. My woofers are mounted in W-style open baffle boxes which tend to have resonances above 100 hz. Thus, the resonances from these woofers are what are causing the problem. I am confident that when I mount these drivers in a different box, that my system would sound fine with the Lowthers crossover over at a higher point.
What (sub)woofers are you using and in what enclosure are they mounted?
Retsel
Previous Topic: Is it my imagination .....OR
Next Topic: what are the best small compact speakers you would suggest?
Current Time: Sat Oct 31 06:01:46 CDT 2026
