Home » Audio » Speaker » P AUDIO - 15" DRIVER AND BAFFLE DESIGN
| Re: P AUDIO - 15" DRIVER AND BAFFLE DESIGN [message #21690 is a reply to message #21676] |
Mon, 28 August 2006 16:25   |
Retsel
Messages: 23 Registered: May 2009
Chancellor |
The point to using low Q drivers is that they are substantially damped leading to lower distortion. What follows is that the higher freqencies of the drivers need to be rolled off so that the sound is flat. The bass below some typical value, such as 150 hz, would be reproduced by a woofer/subwoofer, which helps to reduce dopler distortion. Retsel
By: akhilesh on Tue, 22 August 2006 06:31
By: FredT on Tue, 22 August 2006 07:07
How about the T/S specs of the Silver Iris by Hawthorne?
By: akhilesh on Tue, 22 August 2006 10:21
Eminence Alpha 12 and 15
Re: Eminence Alpha 12 and 15
By: akhilesh on Tue, 22 August 2006 11:15
I know my input is not wanted here...
Re: I know my input is not wanted here...
Well, see, it's this way....
Re: Well, see, it's this way....
By: DanTheMan on Fri, 01 September 2006 00:03
By: DanTheMan on Sun, 03 September 2006 03:49
By: DanTheMan on Mon, 04 September 2006 16:49
By: Martin on Thu, 31 August 2006 08:04
By: Martin on Thu, 31 August 2006 16:41
By: gfederys on Wed, 20 September 2006 13:49
By: gfederys on Thu, 21 September 2006 06:42
By: FredT on Wed, 23 August 2006 06:50
By: Retsel on Thu, 26 October 2006 16:14
Re: How about the T/S specs of the Silver Iris by Hawthorne?
By: FredT on Tue, 22 August 2006 13:44
By: FredT on Thu, 26 October 2006 18:41
By: Retsel on Mon, 28 August 2006 16:25
Current Time: Tue Nov 03 09:41:48 CST 2026
