Home » Audio » Speaker » P AUDIO - 15" DRIVER AND BAFFLE DESIGN
| Well, see, it's this way.... [message #21688 is a reply to message #21684] |
Wed, 23 August 2006 16:42   |
wunhuanglo
Messages: 912 Registered: May 2009
Illuminati (2nd Degree) |
Eddie asked a queston as if sound quality mattered. On that basis I responded as I did. It is my premise (true or not, it's mine) that despite what WinIsd might say a high Qts driver is providing the impression of extended base response by flapping in the breeze. It is not providing an accurate representation of the input signal. As I noted in my original post (assuming that sound quality was important) if you want to go the OB route you have to be prepared to EQ and it's almost mandatory to bi-amp to get the needed degree of driver control. OTOH, if your primary concerns are (personally) satisfying reproduction at minumum investment and not fidelity (which is a matter of personal preference) then I would agree that a high Qts driver is the way to go. But I would also contend that concerns as to how Driver A compares with prized classic Driver B should not be among your criteria for driver selection.
Re: P AUDIO - 15" DRIVER AND BAFFLE DESIGN
By: akhilesh on Tue, 22 August 2006 06:31
By: FredT on Tue, 22 August 2006 07:07
How about the T/S specs of the Silver Iris by Hawthorne?
By: akhilesh on Tue, 22 August 2006 10:21
Eminence Alpha 12 and 15
Re: Eminence Alpha 12 and 15
By: akhilesh on Tue, 22 August 2006 11:15
I know my input is not wanted here...
Re: I know my input is not wanted here...
Re: Well, see, it's this way....
By: DanTheMan on Fri, 01 September 2006 00:03
By: DanTheMan on Sun, 03 September 2006 03:49
By: DanTheMan on Mon, 04 September 2006 16:49
By: Martin on Thu, 31 August 2006 08:04
By: Martin on Thu, 31 August 2006 16:41
By: gfederys on Wed, 20 September 2006 13:49
By: gfederys on Thu, 21 September 2006 06:42
By: FredT on Wed, 23 August 2006 06:50
By: Retsel on Thu, 26 October 2006 16:14
Re: How about the T/S specs of the Silver Iris by Hawthorne?
By: FredT on Tue, 22 August 2006 13:44
By: FredT on Thu, 26 October 2006 18:41
By: Retsel on Mon, 28 August 2006 16:25
Current Time: Tue Nov 03 09:42:19 CST 2026
