Home » Audio » Speaker » FredT -MLTL Bipole speaker impressions
Re: Line Array Speakers [message #21612 is a reply to message #21610] Wed, 28 June 2006 13:07 Go to previous messageGo to previous message
Say Fred; those Selah 8's go for about 4K$ in the kit form; is that right?
That looks like about 6.5/7K$ built. That seems to put you in some pretty rarefied territory; at least in my neighborhood. What are your thoughts regarding this type of committment to the Arrays on that spending level compared to what is out there in the same league?
Off hand 4K$ would say get you a pair of well designed two-ways using TAD drivers. I use that as some kind of example.
If you chose to buy used; I can think of some pretty good speaks out there. Is this something that would supercede what is commonly available at that price? Or is this the result of what you can do with whats on the markett as kits regarding sound quality? I don't know if thats clear; maybe I should explain better?
Thanks.
Previous Topic: Spades for Heresy speaker connections
Next Topic: System Improvement
Current Time: Sat Oct 17 04:17:20 CDT 2026
