Home » Audio » Speaker » Goodmans Update - Bass and Notch
Goodmans Update - Bass and Notch [message #21598] Fri, 23 June 2006 09:22 Go to previous message
I was able to spend some time with the Goodmans Axiette this week and was very surprised by a couple of findings.
First was the bass. According to the T/S parametres I measured and Boxplot, these drivers can extend down to 30Hz in a 3 1/2 cu ft box. It just so happens that I have a box of that size available in the form of my 3-PI Theatres. I made an adaptor for the Goodmans to fit on the baffle and guess what? It does go down that deep! I'm guessing its about -10dB at that point, but it's clean, clear and detailed. I still can't believe these little guys can actually pump the way it does. Now I'm rethinking my intent to cross with a sub.
The second surprise was what it took to tame the mids. These speakers sound very mid-rangey when used naked. I connected a 10-band eq to the system and played with the settings for a couple of hours to find where the problem areas were. What it took was simple attenuation at 1kHz. Not by -3dB or -6dB. But as far as the eq can go, to -15dB. At this setting the drivers had an extremely netural tone, but I'm finding it surprising that it takes such an extreme attenuation at such a specific frequency.
I don't have a lot of experience with correcting fullrange drivers, so I'm wondering this is common. Also, wondering what the pros and cons are between narrow/steep vs wide/shallow band notch filers. Is the phase shift resulting from a narrow/steep filter audible?
Gar.
Previous Topic: User Feedback DCA 5.5 and 4
Next Topic: DCA 5.5M drivers initial impressions
Current Time: Mon Nov 16 07:25:55 CST 2026
