Home » Audio » Speaker » Integrating full-range as wide-range
Re: Integrating full-range as wide-range [message #21590 is a reply to message #21589] Mon, 12 June 2006 07:32 Go to previous messageGo to previous message
I would think that applying the high pass in front of the amp, even passively would give even better results than at speaker level. It would allow you to run the amp higher before clipping in the trebles. It could be as simple as reducing the input coupling cap by a factor of 10.
Previous Topic: Xover and line array
Next Topic: Measured T/S parameter for Goodmans Axiette 8 II
Current Time: Mon Oct 26 03:11:43 CDT 2026
