Home » Audio » Speaker » Integrating full-range as wide-range
Re: Integrating full-range as wide-range [message #21571 is a reply to message #21565] Tue, 06 June 2006 06:19 Go to previous messageGo to previous message
HI Gar,
You can use a sealed box, but then your JBLs will be doing work till about 150-200 Hz. THis will cause imaging/coherence issues. My suggestion is to measure the axiettes and build a BR box for them, then cross them over an octave higher with the JBLs. My guess is the axiettes should be capable of producing 50 Hz or so in a well designed BR box. Design a box that does that (you'll have to measure the drivers to be sure of course) and then cross over an octave higher. Try different slopes. i'd start with at least a 12 db slope each way.
This will give you coherence and imaging.
-akhilesh
Previous Topic: Xover and line array
Next Topic: Measured T/S parameter for Goodmans Axiette 8 II
Current Time: Sat Sep 12 00:39:26 CDT 2026
