Home » Audio » Speaker » Void Filling Foam?
Re: Void Filling Foam? [message #21561 is a reply to message #21559] Sun, 04 June 2006 19:22 Go to previous messageGo to previous message
Skip is currently offline  Skip
Thanks for the info. I looked at Great Stuff on the
product web site. I sounds like you would want put a small
amount into the speaker, let it cure and then add some more.
Sounds like you get a better cure, and avoid over pressuring
the wood.
Skip
Previous Topic: GPAF Treasure
Next Topic: Mounting an 811 horn
Current Time: Sun Nov 01 17:52:44 CST 2026
