Home » Audio » Speaker » GPAF Treasure
Re: Initial Impressions [message #21516 is a reply to message #21513] Sun, 28 May 2006 21:27 Go to previous messageGo to previous message
Fred,
Thanks for the update on your speakers. I agree that the bass is very good for these little drivers within limits but they aren't capable of pro sound output levels.
My on-axis measured data shows performance within a 5 dB (that is + 2.5/-2.5 dB) window between 1000 Hz and above 20,000 Hz. That is exceptional for an inexpensive full range driver. Off axis the treble beams a bit as you would expect. Of course you don't have quite the sparkle that a quality tweeter would convey. I can send you a copy of my measured data if you wish.
On my speakers I used a single run of Canare 4S8 wire (4 16 awg copper conductors) to connect between the terminal plate and the drivers.
The bipolar nature of these speakers do add a bit of ambience that will disturb the purist who wishes to have a small sweet spot. As you suggest they project much like live music versus sounding like speakers.
Again thanks and I appreciate your efforts.
Jim
Previous Topic: Line Arrays on Audiogon
Next Topic: Void Filling Foam?
Current Time: Sun Nov 01 19:01:17 CST 2026
