Home » Audio » Speaker » I wish I would have thought of this-- new PVC design
Re: I wish I would have thought of this-- new PVC design [message #21487 is a reply to message #21481] Sat, 22 April 2006 08:25 Go to previous messageGo to previous message
scottallen is currently offline  scottallen
Use flexible corrugated drain pipe. Nautilus is tapered; driver end big to small. It maybe closed at small end. Interior corrugation should help take out some highs. To make end smaller: melt with hot iron? or cut lengthwise and reduce? Put pipe the way you want, wrap with wire and coat with thin layer concrete. Whichever taper you want small to big, big to small. open or closed
Previous Topic: Comments on Eminence LA6 Series?
Next Topic: line array
Current Time: Mon Nov 02 05:58:18 CST 2026
