Home » Audio » Speaker » Adding super-tweeter to my Fostex FE-206's
Re: Adding super-tweeter to my Fostex FE-206's [message #21457 is a reply to message #21455] Tue, 28 February 2006 22:17 Go to previous messageGo to previous message
Do the FE206's have a BSC circuit?
I ask because my gut feeling is that if the overall system sensitivity is 93-95dB then I think the DX25 would be better. If it's 96-98dB then the MG27 would probably be better. It wouldn't be cost prohibitive to try them both and see. As far as cap value, that depends on what frequency you want to crossover. The DX25 allows a fairly low crossover point, so you can take advantage of that if you like.
Previous Topic: ALTEC VALENCIAS
Next Topic: What is the optimal frequency range for a single driver to reproduce?
Current Time: Tue Nov 03 14:20:11 CST 2026
