Home » Audio » Speaker » Adding super-tweeter to my Fostex FE-206's
Re: Adding super-tweeter to my Fostex FE-206's [message #21452 is a reply to message #21450] Tue, 28 February 2006 12:03 Go to previous messageGo to previous message
Peter Swartz is currently offline  Peter Swartz
As I am in a very near field application, could you recommend a nice cloth dome tweeter, 4ohm vrs. 8ohm? Minimal sensitivity to match the 206? Should I expect to use a variable pad to adjust the volume of the tweeter or is this a bad sonic idea? After I choose a driver where can I learn more info as to what specific cross-over components to use, values,brand etc.. for the best results? Since the 206 has a bump around 10k I'm actually only interested in using the tweeter for 15k and above, easing in around 12k. Does this seem like a good way to go? Thanks again for your advice, Pete
Previous Topic: ALTEC VALENCIAS
Next Topic: What is the optimal frequency range for a single driver to reproduce?
Current Time: Tue Nov 03 16:22:20 CST 2026
