Home » Audio » Speaker » Ciare HX-201 10" wideband?
Re: Ciare HX-201 10" wideband? [message #21417 is a reply to message #21404] Tue, 10 January 2006 13:31 Go to previous message
robertG is currently offline  robertG
If you plan to use it in a three way system, why bother with a 10 inch driver?
I mean, you could get away with a much nicer 5 or 6 in. driver with a smoother roll-off, such as Fostex extended range woofers.
Previous Topic: Cheap and easy phase plug
Next Topic: Updated the crossovers on my K-orns to spec
Current Time: Sat Nov 28 17:52:06 CST 2026
