Home » Audio » Speaker » Cheap and easy phase plug
Re: Cheap and easy phase plug [message #21407 is a reply to message #21406] Sat, 31 December 2005 22:51 Go to previous messageGo to previous message
Hi Dave,
I would be interested in such a compact highly efficient tweeter. If you come up with one, please post your resuslts?
Also, let us know how your phase plug experiments go?
I would like to find an efficient 8" fullrange driver, 96db or more, that does not have a whizzer cone and can be run without a crosover on an OB down close to 80Hz.
So far, most of the drivers that I have seen that would work in this range, have large peaks starting around the 2kHz to 9kHz range.
I thought a phase plug could help tame these peakes somewhat.
I would like to stay away from any EQ or crossovers in the critical midrange if possible.
Some of the German 20cm fullrange drivers look promising.
Any suggestions?
Norris
Previous Topic: What measurements matter to audibility?
Next Topic: Ciare HX-201 10" wideband?
Current Time: Sat Nov 07 23:43:35 CST 2026
