Home » Audio » Speaker » best driver for voigt pipes
Re: best driver for voigt pipes [message #21393 is a reply to message #21381] Sat, 17 December 2005 11:01 Go to previous message
GM is currently offline  GM
>I guess that I will have to read the text of Voigt's patent again, but I don't see either the B-is-B or the LCN pipe matching the figures. But, then they could be easily considered correlaries of one or more of the figures.
Greets!
No, not per se since the written portion just gives an example, not a 'carved in stone' design like some folks have interpreted it, with the drawings indicating the various concepts not covered in the various Bell Labs/W.E. patents.
>The terminalogy used today fits neither the physics or the history of pipe design. I guess this is my main point. Voigt pipes, MLTL's, TL's, TQWT's, back horn, corner horn, you get the picture.
Well, the physics hasn't changed, not sure what you mean WRT history, and for sure the nomenclature has changed over time. ML-TLs, multiple resonant cavity (BP) designs were lumped in with 'reflex', Voigt pipes/any flavor of TL were lumped together as 'Acoustic Labryrinths', and anything that had a positive expansion was a horn regardless of whether it had a reduced exit (vent) or not.
>I agree with you (agreeing with me?) that the B-is-B is a corner loaded back horn. As such it works completely different from the LCN TQWT. So, I can't consider them the same or correlaries of each other.
Anyway, keep me straight!
Bob
Right, though located as shown in his write-up it's just a folded BLH since it's too far from the corners/ceiling for proper loading, though my SWAG is they're close enough for some down around Fc.
GM
Previous Topic: needles type array or full tweeter line array
Next Topic: folded voight pipes???
Current Time: Mon Oct 19 18:29:23 CDT 2026
