Home » Audio » Speaker » what are power extremes/ or nominal power to be....
Re: what are power extremes/ or nominal power to be.... [message #21356 is a reply to message #21354] Fri, 25 November 2005 16:35 Go to previous message
I'd build the speaker first, and try it wth your current amp. Then, if you like, you can try a SET amp. But first, it would be good to hear the speaker and see if you like it. Changing to a SET amp will make a difference, but not a huge one.
Hope this helps. Just my 2 cents.
-akhilesh
Previous Topic: Folded horns with curves, about 60 – 500 Hz
Next Topic: Conical front horn
Current Time: Mon Nov 02 08:50:24 CST 2026
