Home » Audio » Speaker » installing Lowthers in King BR box
Re: installing Lowthers in King BR box [message #21332 is a reply to message #21331] Fri, 21 October 2005 05:04 Go to previous message
Martin is currently offline  Martin
Hi Jim,
The only change to the port is to shorten it to two inches long, The Lowther has a higher fs then the Fostex so the enclosure needs to be tuned higher.
If you are using a correction circuit you may also need to reduce the parallel resistor a few ohms. Take a look at my updated correction circuit values in Project 5 and select a smaller resistor then you are using and the corresponding inductor. I also found that adding a small cap in parallel helped bring up the high end a little, this cap and its value is shown in my Project 4 final circuit.
Hope that helps,
Martin
Previous Topic: Array Me in the Right Direction
Next Topic: DIY2005 Orlando new venue info
Current Time: Tue Nov 03 16:21:52 CST 2026
