Home » Audio » Speaker » Benefits of a wideband driver for off axis decay
worth 1.0k words [message #21323 is a reply to message #21322] Thu, 06 October 2005 12:20 Go to previous messageGo to previous message
Hi Bob,
Yes I enjoyed your speakers at GPAF, and have enjoyed your website as well.
The on- and off-axis curves you posted are most informative - thanks! I would guess that somewhere between the top two curves - maybe around 15 degrees ballpark - the first-arrival response is smoothest. Then the rising on-axis energy instead becomes reverberant energy, helping to maintain a better tonal balance for the reverberant field than you'd normally get from "flat on-axis" speakers.
For the sake of a wider listening area, I toe my Fostex's in so that they criss-cross in just front of the listener rather than just behind. Also, the FE206E isn't as smooth as the FE167E (more energy between 2k and 10k), so I use a broad, gentle notch filter to bring that region down just a skosh.
Duke
Previous Topic: Orions
Next Topic: Ping Earl Geddees!
Current Time: Mon Nov 02 12:21:09 CST 2026
