Home » Audio » General » Blind testing and what I would like to see done...
Re: Blind testing and what I would like to see done... [message #2131 is a reply to message #2128] Thu, 25 August 2005 07:33 Go to previous messageGo to previous message
Mr Vinyl is currently offline  Mr Vinyl
Hi Manualblock,
As I said earlier I am no expert in DBT's. However I don't think these tests are trying to show which component sounds better but instead if a difference can be heard at all. In other words, listen to Amp "A" then switch to Amp "B" did you hear a difference, yes or no. First you would have to determine if a difference between say amps or cables can be heard at all, and then you could go from there.
Previous Topic: Tascam 133
Next Topic: Hey Charlie, man are you out there?
Current Time: Tue Nov 03 18:44:33 CST 2026
