Home » Audio » Speaker » Why do they cost so much??
Not a problem . . . [message #21276 is a reply to message #21223] Sun, 04 September 2005 21:36 Go to previous messageGo to previous message
Poindexter is currently offline  Poindexter
That's because you shunt the problem to Dr. Ted, who has torn his hair out over this predicament for years, and now makes the solution available to you for mere hundreds of (Shrub devalued) US$.
Deferring the problem does not remove it, it just removes it from your sight, if you are short-sighted.  I reiterate; a driver that can output an acoustic watt into an average room with flat freqency response over ten (okay, nine) octaves, and okay dispersion on top, is an engineer's nightmare.
So, it's not your nightmare.  Lucky you;  blow a kiss at Dr. Ted.
Aloha,
Poinz
Previous Topic: Two horn theory papers
Next Topic: Going from 3 to 12 tweeters...
Current Time: Sat Nov 28 20:30:00 CST 2026
