Home » Audio » Speaker » Fostex 167E distortion
Re: FE127e [was] Re: Fostex 167E distortion [message #21273 is a reply to message #21272] Sat, 03 September 2005 21:12 Go to previous messageGo to previous message
GM is currently offline  GM
>FX200 has been mentioned by GM as a drop in replacement.
Greets!
I believe you meant FX120........
That said, assuming you didn't get carried away cutting out the mounting holes, the new CSS 125S is a slightly smaller, but still drop-in once you drill new mounting holes, and sims better overall in your cabs than either the Fe127E or FX120. I gather from your remarks that strong bass isn't desired, so you may have to either extend the vents to 8" or damp them to suit.
GM
Previous Topic: Going from 3 to 12 tweeters...
Next Topic: I need to locate a custom speaker builder/company or someone to just exchange a coil for me
Current Time: Mon Nov 09 20:09:13 CST 2026
