Home » Audio » Speaker » A little article about a BLH....why go to the trouble.....
Re: Mouth Area and Cut-Off Frequency [message #21263 is a reply to message #21261] Fri, 26 August 2005 09:17 Go to previous messageGo to previous message
Retsel is currently offline  Retsel
Thanks for the suggestion and some day I may try one, and if I do I would just try to borrow one to see if I would like it.
I am skeptical. I am skeptical because I am much more sensitive to transparency then most audiophiles. I work to remove as much from the signal path as possible. For example, years ago when people were raving about the Genesis digital lens, I tried one in my system and immediately removed it because it reduced the transparency of the sound.
In recent years I have been soldering or terminating my speaker wires and interconnects directly to my components to avoid the RCA connectors or speaker binding posts which rob the sound of its transparency. I wired my SACD player to remove all resistors from the signal path. I go directly from the digital chip through a set of mu metal transformers to the output. Thus, I am pretty aware of what I would like and what I would not like. I probably would not tolerate such a device in the signal path.
The upshot from taking these actions is that the sound from my system is amazing.
Retsel
Previous Topic: Array with Aurum G1 and Extremis?
Next Topic: Bass horn pic
Current Time: Fri Oct 16 14:06:42 CDT 2026
