Home » Audio » Speaker » A little article about a BLH....why go to the trouble.....
Re: Mouth Area and Cut-Off Frequency [message #21252 is a reply to message #21251] Mon, 22 August 2005 08:31 Go to previous messageGo to previous message
Retsel is currently offline  Retsel
You are right. I mistakenly used an equation that already assumed 1/4 pi space and I was doubling the horn opening thinking that it was not.
However, I do not need to pad down upper frequencies in the Hedlund Horn to get balanced reponse. The Hedlund Horn is balanced from 80 - 100 hz up to 10 khz. Perhaps there is a combination of horn and tranmission line bass which gives the balance that the Hedlund Horn enjoys, or perhaps it is the room reinforcement. This is not just to my ears but to any who have heard my system.
The subwoofer I was using does not provide much boost for the mid bass as I was crossing it over at 38 hz with a third order crossover. The subwoofer is very desirable, though, for most all music.
Retsel
Previous Topic: Array with Aurum G1 and Extremis?
Next Topic: Bass horn pic
Current Time: Fri Oct 16 14:06:26 CDT 2026
