Home » Audio » Speaker » A little article about a BLH....why go to the trouble.....
Re: Horns, transmission lines and reflex cabinets [message #21250 is a reply to message #21248] Sat, 20 August 2005 06:22 Go to previous messageGo to previous message
Martin is currently offline  Martin
When you place Lowther DX4s in tranmission line cabinets, do you need to pad down the upper frequencies or does the cabinet bring up the bass sufficiently to match the upper frequencies so that no equalization is required?
In all the designs I have built and measured, you need to pad down the upper frequencies with a correction circuit. The cabinet can be designed to produce bass equal in efficiency to the driver radiating into 2 pi space. However, by placing the enclosure out in a room the baffle step will exist which requires correction.
Martin
Previous Topic: Array with Aurum G1 and Extremis?
Next Topic: Bass horn pic
Current Time: Fri Oct 16 14:06:46 CDT 2026
