Home » Audio » Speaker » A little article about a BLH....why go to the trouble.....
| Re: Horns, transmission lines and reflex cabinets [message #21206 is a reply to message #21205] |
Thu, 11 August 2005 10:05   |
Messages: 19102 Registered: January 2001
I think your assessment is correct. But I also think it's important to look closely at this, because small basshorns are the same thing as tapered pipes in all but name. Bass-reflex speakers provide augmented bass output too. So to talk about the differences, one must first look at the similarities. There's a huge amount of overlap in each of these designs.Each will have Helmholtz resonance, determined by the dimensions of the exit hole and the volume of the cabinet. Helmholtz resonance is normally associated with bass-reflex speakers, but it is just a physical property that happens when you have a chamber with a hole in it. There will also be standing wave modes, determined by cabinet dimensions, component placement and geometry. And there may be some horn action, depending on flare rate and environment, like corner loading. So there will be each of these properties, whether the speaker is called a reflex system, horn or transmission line. The overlap of each of these makes them more similar than different.
By: Retsel on Wed, 10 August 2005 13:41
By: Retsel on Thu, 11 August 2005 07:15
By: Retsel on Tue, 16 August 2005 09:44
By: Martin on Tue, 16 August 2005 17:48
By: Retsel on Thu, 18 August 2005 08:08
By: Retsel on Thu, 18 August 2005 09:32
By: Martin on Thu, 18 August 2005 15:37
By: Retsel on Fri, 19 August 2005 08:05
By: Martin on Sat, 20 August 2005 06:22
Mouth Area and Cut-Off Frequency
By: Martin on Sat, 20 August 2005 14:16
Re: Mouth Area and Cut-Off Frequency
By: Retsel on Mon, 22 August 2005 08:31
By: Martin on Thu, 25 August 2005 18:23
By: Retsel on Fri, 26 August 2005 09:17
By: Retsel on Mon, 03 October 2005 10:41
By: Retsel on Mon, 03 October 2005 14:41
By: Chris K on Thu, 18 August 2005 20:29
By: ChrisK on Thu, 18 August 2005 22:17
Maximum SPL charts
Re: A little article about a BLH....why go to the trouble.....
A W-bin!
Re: A W-bin!
Hurt me; hurt me!
Re: Hurt me; hurt me!
You have mail, Bob.
Current Time: Fri Oct 16 14:06:14 CDT 2026
