Home » Audio » Speaker » A little article about a BLH....why go to the trouble.....
| Re: Horns, transmission lines and reflex cabinets [message #21183 is a reply to message #21181] |
Sun, 07 August 2005 08:36   |
Messages: 19102 Registered: January 2001
Here's the thing, Ed. It isn't fair for you to pounce on Bob's statement, "Single-driver full-range speakers have a limited dynamic range." That was a statement of fact, and you shouldn't use it to launch a campaign. It isn't a statement about horns or transmission lines, it is a statement about single drivers.A backloaded horn doesn't increase efficiency through most of the passband. It only increases output at low frequencies, to augment where the driver is getting weak. So it doesn't help efficiency. The reason I've suggested comparing the horn and the transmission line is that I believe that they are more alike than different. When used at bass frequencies, a horn has to be pretty large. When it is made small, it is really a tuned pipe. Cornerhorns are small tuned pipes that use the corner as the mouth. The physical construction of a small backhorn is very similar to that of a transmission line. They act pretty much the same. Put a transmission line in the corner, and it acts very much like a backhorn placed in the corner. Alternately, take a backhorn out of the corner, and it becomes a tuned pipe. I think it is productive to look at these things, even if just done in models. That will show you what I say is true. You know how I know? Because I've done it.
By: Retsel on Wed, 10 August 2005 13:41
By: Retsel on Thu, 11 August 2005 07:15
By: Retsel on Tue, 16 August 2005 09:44
By: Martin on Tue, 16 August 2005 17:48
By: Retsel on Thu, 18 August 2005 08:08
By: Retsel on Thu, 18 August 2005 09:32
By: Martin on Thu, 18 August 2005 15:37
By: Retsel on Fri, 19 August 2005 08:05
By: Martin on Sat, 20 August 2005 06:22
Mouth Area and Cut-Off Frequency
By: Martin on Sat, 20 August 2005 14:16
Re: Mouth Area and Cut-Off Frequency
By: Retsel on Mon, 22 August 2005 08:31
By: Martin on Thu, 25 August 2005 18:23
By: Retsel on Fri, 26 August 2005 09:17
By: Retsel on Mon, 03 October 2005 10:41
By: Retsel on Mon, 03 October 2005 14:41
By: Chris K on Thu, 18 August 2005 20:29
By: ChrisK on Thu, 18 August 2005 22:17
Maximum SPL charts
Re: A little article about a BLH....why go to the trouble.....
A W-bin!
Re: A W-bin!
Hurt me; hurt me!
Re: Hurt me; hurt me!
You have mail, Bob.
Current Time: Fri Oct 16 12:57:55 CDT 2026
