Home » Audio » Speaker » Why won't a single driver speaker do metal?
Re: Why won't a single driver speaker do metal? [message #21169 is a reply to message #21086] Sat, 06 August 2005 12:15 Go to previous messageGo to previous message
Greg B is currently offline  Greg B
Since no one else has pointed it out: 'metal' is not dynamic music. In fact, it's severely limited and almost the opposite of classical. Massive amounts of compression are used in recording and mastering, aside from the natural compression of marshall amplifiers in overdrive.
I've rarely found any metal to sound good on horns or other dynamic speakers. It is mastered to sound good on typical home stereos. Metal sounds best IMO on lower efficiency but fairly large multiways, but can be OK on low efficiency single drivers, like say the cheap delco fullranges in your camaro... I've listened to enough metal as a teenager for one lifetime already, but that's a different subject.
To sum it up, I think it's more a matter of efficiency and low distortion. Heavily produced rock and metal thrive on a bit more compression and squashing of the peaks even at the playback end; while classical, jass and other well recorded music sound best with higher fidelity. I doesn't surprise me that little fostex FR's in small backhorns sound pretty good with metallica, as they are not that efficient and no doubt squash dynamic peaks.
Greg B
Previous Topic: interesting auction item
Next Topic: Driver Size Thoughts
Current Time: Tue Oct 20 17:26:28 CDT 2026
