Home » Audio » Speaker » Why won't a single driver speaker do metal?
Re: Why won't a single driver speaker do metal? [message #21119 is a reply to message #21088] Sat, 30 July 2005 11:02 Go to previous messageGo to previous message
2. The solution I use is a lot simpler: Use a sub for the lower frequencies. THis takes care of the SPL issue.
So very true! If the FR is in a sealed (very small volume) and allowed to run FR with the sub being rolled off at 200-300 hz (i perfer sealed again for the woofer) and both are bi amped then you have a very effective system thats a simple build.
Although i am a horn nut , this method is very simple ( to me anyway) as i use gainclones and can wip one up in around one hr.( case not included). Or just put a cap on the front end of one of those little Sonic T amps for the roll off of the woofer and use another for the FR.
There ya have it a cheap/simple effective system that probably would cost < 500$ with a quality FR driver and woofer.
ron
Previous Topic: interesting auction item
Next Topic: Driver Size Thoughts
Current Time: Tue Oct 20 16:12:32 CDT 2026
