Home » Audio » Speaker » Why won't a single driver speaker do metal?
Re: Why won't a single driver speaker do metal? [message #21099 is a reply to message #21091] Tue, 26 July 2005 23:53 Go to previous messageGo to previous message
Bob Brines wrote:
"It won't work for the SET crowd because the cross over has to be done either digitally, which kind of takes the shine off of vinyl, or has to be done actively at the pre-amp level which normally means some OP amps."
Actually, I use the Xover in the preamp mode, and then use a SET (a 45 SET) to drive the "single driver". Sounds quite nice to me. I don't personally believe the opamps make a difference, (any more so than the myriad other phase shifts caused by passive compknents, which I donlt have, box, room reflections, etc). I have experimented with the same driver ( in the same box) in single driver mode, single driver with BSC circuit mode, "single driver" with super tweeter and BSC mode and finally, "single driver" with super tweeter, sub & active Xover mode. THe single driver with super tweeter, sub & active crossover sounds by far the cleanest and the most involving.
But this is just my opinion, and may be different for different setups.
-akhilesh
Previous Topic: interesting auction item
Next Topic: Driver Size Thoughts
Current Time: Tue Oct 20 17:26:31 CDT 2026
