Home » Audio » Speaker » fullrange single driver help please!!
Re: fullrange single driver help please!! [message #21013 is a reply to message #21001] Mon, 13 June 2005 17:17 Go to previous messageGo to previous message
robertG is currently offline  robertG
The rising response in full-range (larger) drivers is a necessary evil. The cone needs a very powerfull motor system, meaning large magnet, very light cone and tight tolerances. A high power to weight ratio. That's the only way a driver can hope to deliver both bass and treble at the same time. The resulting very low Q value driver needs to be mated to an enclosure that will enhance the bass and mids to match the treble output. Welcome the back horn.
But all drivers are not that bad! First of all, allow for proper break-in. The use the right enclosure. And the right amplifier (such as a low damping factor tube amp).
If using a SS amp (as I do on my FE168EZ), try a (series) 4 to 10 ohms non-inductive resistor. In my case, I noticed what seemed like a 6dB boost in bass, and a "magic" drop in low treb output, while retaining vry HF sound.
Previous Topic: Axon 8-12 array
Next Topic: Tangband W3-871 fullrange
Current Time: Tue Nov 03 15:22:03 CST 2026
