Home » Audio » Speaker » fullrange single driver help please!!
Re: fullrange single driver help please!! [message #21008 is a reply to message #21006] Thu, 09 June 2005 15:46 Go to previous messageGo to previous message
Peter Swartz is currently offline  Peter Swartz
Hi Martin, It sounds like you are just the person I need for advice.
Unfortunatly I am unable to open the links associated with your project articles. Perhaps you could email them separatly for me concerning the 206. I have been looking into graphic and parametric
EQ's. Any suggestion as to which sounds better? Active vrs. passive?
Looking at your correction circuits, it looks like there is no avoiding adding to my signal path.
I would like to give your circuit a listen. I'm using consonance SET M500 9 watt mono blocks and a passive/pre. I would greatly appreciate it if would please list for me specifically which components you would recommend for me with maybe three different resistor values I could swap out. Schematic also of course.
Please be specific with value, brand, tolerance etc.. so I may simply goto the electronics store or pick up the phone to parts express.
My cabinets are approx. 45 liters volume with a 3" Dia. x 3"long port.
The cabinet is an odd shape though.
Perhaps I could call you? My number is 310-202-1862 LA, California.
After reading the June Stereophile article on the fine quality and sound of the old C-500 Fisher recievers tone controls, etc...
I'm considering sending my Dad's old Fisher CX2-400 their top pre-amp to Fisher Radio for rebuilding primarily so I could us the tone controls, sound crazy?
Thanks again for you expertise!
Sincerely, Peter
Previous Topic: Axon 8-12 array
Next Topic: Tangband W3-871 fullrange
Current Time: Tue Nov 03 13:21:57 CST 2026
