Home » Audio » Speaker » requesting opinions on fullrange array
Re: requesting opinions on fullrange array [message #20950 is a reply to message #20948] Tue, 31 May 2005 14:32 Go to previous messageGo to previous message
Try to isolate the problem. Here are a few questions that might shed some light on things:
1) Does the subwoofer amp hum with no input?
2) Does the receiver hum when the sub amp isn't connected?
3) When everything is connected, does the hum come from the sub, the receiver or both?
4) Why do you run a signal back from the sub to the receiver instead of just going one way?
5) Are you using an effects output like for an equalizer, that splits the preamp from the amp section of the receiver?
6) If so, have you tried leaving the straps in place, and using another preamp output instead, like perhaps a tape monitor output?
Previous Topic: Parallel Notch Filter Question
Next Topic: ESL web sites
Current Time: Wed Nov 04 06:50:29 CST 2026
